Re: 6 hp Nissan four stroke valve adjustment - how to?
You should loosen the exhaust up a bit.
On my diesel the exhaust setting is double that of the intake. My intake valve lash is set to .010 inch, and the exhaust is .020 inch. My understanding is that the exhaust valve(s) have to deal with more heat, and the larger cold gap will compensate as it warms up. If too tight, the valve could be held open slightly, losing a bit of compression, power, and efficiency. You also risk burning the valve and valve seat.
I just looked at my Mercury (Tohatsu) 6HP, and the sticker on the the front (forward) side of the block has the valve settings on it. the intake is .06mm, and the exhaust is .011mm.
