6 hp tiller lower unit replacement
hamburgerman
I changed out the water pump now I cant seem to get the lower unit to line up . I have done it 3 other times over the years with no problem ,I bet I got about 15 hrs. in trying this. first time it went right together then i noticed that the shift linkage was wrong so i pulled it back apart. Now I cant get it to go back together please help!
Wingedwheel
Re: 6 hp tiller lower unit replacement
Did you try turning the flywheel by hand while pushing the LU into place. Sometimes the splines aren't quite aligned and that usually helps.
