I have a 3 year old tohatsu 6hp extra long shaft for my sailboat. Has run great till about a month ago. I was going out, the motor had been running for about 10 min. when it suddenly stalled. I was able to restart it easily but when I put it back in gear it bogged down and stalled. It did this several times but I made it to the lake and sailed for an hour or so and it restarted but stalled again several time when put in gear. I managed to finally get it to run long enough to dock. I read on this forum and others about this problem and it seemed a carb cleaning was in order. I also read that some had used SeaFoam with success. I tried that a few days later. I ran rough for a few min. then it ran OK. I made sure it was securely tied to the deck and put it in gear forward and reverse. Ran OK. For the next month everything was OK.
Then Monday the same thing as above happened. Restarted OK, usually on the first or second pull. We sailed for an hour and came in. This time it bogged down once but we got back without incident.
This evening same thing happen after running about 10 min. This time I couldn't get it restarted for about 10 min. Cranked my guts out. Finally restarted and I let it run a while. As soon as I put it in gear it stalled. I did this repeatedly. Every time it stalled immediately or ran for only a few seconds and stalled. Fortunately, we were upwind of the marina and managed to get back OK. Also, this time it was backfiring quite a bit. When it started and almost started and when it stalled. Never did that the previously.
Any ideas on the problem? Fuel pump and filter seem to be OK. I pulled the motor and have it at home now. I have a stand and a large container which I use in the spring to test it out so testing won't be a problem but do I need a carb rebuild kit? Filter? I haven't check the plug yet but last month I did when this started and it was OK. Seems to be a fuel problem.
