- Joined
- Sep 26, 2009
- 20,217
Here's the compressor I'm hooking up, finally. 1st pic shows the whole unit. I'm in mockup stage. I'll be putting a shutoff valve between the tank and the filter. Question is about the filter. First of all, the instructions are useless. The first canister is a filter, then the regulator and finally the oiler. The oiler is where the question is. I'm assuming the oiler is to lube the air tools. Takes the place of of using a couple of drops in the tool before using. But, wont it oil the inside of the air hose too? I'm assuming that would be a bad thing if I ever wanted to attach a spray gun? Can I just use the oiler as a second filter? Or, am I completely off base in my thinking? I forget what was discussed since it's been awhile since I purchased this equipment.
