60 HP - Carb Butterflies Not Wide Open at WOT
atengnr
Ive got the manifold off to get rid of the VRO pump, and I happened to check the position of the butterflies with the throttle lever at WOT. Butterflies are not at a 3 oclock/9oclock position. They are at more of a 2 oclock/8 oclock position. Is this the way it is supposed to be??
If not, how do I correct?
Thanks.
Silvertip
Re: 60 HP - Carb Butterflies Not Wide Open at WOT
Link & Sync first followed by throttle cable adjustment. DO NOT adjust the throttle cable trunion to to make them open wider. That will only prevent them from closing fully at idle. You need a service manual for this procedure as its far too detailed to go into here.
atengnr
Is the position Ive described improper or about right??
iwombat
It's not correct as described. Link and sync is in order.
atengnr
Thanks. So I should see a substantial gain on the top end when I have this set correctly?
