Okay, mY 60 HP force outboard is stuck in fwd gear. When it is on the lake the gear / throttle will move from fwd through neutral and into rev but the only change I see is in rpms. The prop continues to spin even in neutral. I took apart the remote control and everything inside looks good and seems to be working like it should. My cables are moving as they should but the shift lever on the motor does not seem to want to move. I hate to have to open up the lower unit (I've never been in there before) but I hate having this thing sit on someones lot even more and $$ is an issue too. What should I be looking for and how much trouble is it to get into it myself?<br /><br />Thanks
