I've got a 99 60hp mercury (3cyl) that is only firing on one cylinder (ctr). The top and bottom cylinders are not firing. The problem started three weeks ago when the motor started being hard to start. After changing plugs motor would start and run fine. If I shut it down momentarily and bumped starter it would restart no problem. After it sat a while and it would be hard to start again. After changing plugs several more times (on the water)I found that the top and bottom plugs were wet and had not fired at all. Checked spark on all three cylinders. Spark appears to be weak, not bright or with a audible snap. Motor is charging okay,14V. Bad switch box? Coils? Thanks
