60 hp mercury miss
shadetree1
i am running a 1999 60 hp mercury when i get to wot i get a real bad miss can back it off just a little and this clears up.. the motor also starts to over heat at a high rpm, any suggestions??
i have cleaned the carbs, replaced the fuel pump, and just had to replace the water pump and housing, still with no luck
any help would be greatly appreciated!
Faztbullet
Re: 60 hp mercury miss
Check to see if:(a) water pump is working correctly (b) it has the correct plugs/heat range installed (c) max timing is correct. Anyof the above can cause the problem you describe do to preignition.
shadetree1
i have checked the water pump, will try the plugs and timing tomorrow.. and will repost the results
thanks!
shadetree1
checked the timing today and it was advanced about 6 deg too much but since its raining here have not had time to get it back in the water as of yet. thanks for the input!
Jacket4life
Hey shade-
I could be wrong, but doesn't that motor have t-stats too?
shadetree1
Jacket, yes it does but that was also replaced. It only overheats and skips when at wot can drop it down about 1/8 on the throttle and it cools right back down and runs perfect!
shadetree1
Worked on this motor yesterday and I think I have it figured out! Timing adjusment seams to have cured the overheat problem and ended up replacing the rev limiter put it back in the water and she never skiped a beat! Thanks everyone for the help!
