Why? The pinion gear on the driveshaft is always turning, even in idle. The spinning gear is causing an eddy current in the lube which is directed against the reverse gear making the prop spin lazily in the forward direction and can be stopped with a finger. There is no power, but for safety's sake, use a stick or just trust us.
Normal.
