teenbuilder
- Joined
- Apr 22, 2009
- 8
ok well i own a 1961 sea king motor. its a 60 horse power motor with 4 cylinders. it came with a boat project that me and a friend started. so heres the problem. it wont start. before we took most of it apart and found that we werent getting any fuel to the cylinders. we took off the carb and this other fuel distribution system and there was a gasket that was just a solid thing of rubber that when you tried to pump fuel through it then nothing came out. we fixed that and so now fuel should be going through it. well theres something else now that we think that might be clogging it cuz the fuel dosent hit the cylinders it just drains through the exhaust at the bottom. even after only squeezing the bulb a few times thats what happens. any hypothesis as to why it does that? also when we try and start it the cables goin from the battery to the 12 volt converter thing gets really hot and then the wires we solderd melts and comes apart cuz it gets so hot. that also happens when the battery is dead. when the battery if fully charged we try and start it and the 12 volt converter just clicks then turns everything off. someone plz help me with this. its gone from something that looked pretty simple to me to becoming the biggest pain of a motor ive ever had to work on.
