60ESL70 Compression
orbanp
Hello Everyone,
I am wondering what is the range of compression in those 3-cylinder engines? What is considered a lower limit?
I could not find anything in the manuals.
Also, what is the difference between an 60ESL70 and 60ESL70B?
Thanks, Peter
JB
Re: 60ESL70 Compression
Look for over 100psi and all three in a 10% range.
oldcatamount
The compression numbers are rarely printed because of the variation in motors. The main concern is the differences between the cylinders and not so much the numbers themselves. Ideally, a 10% difference is the maximum. I'm guessing the numbers in your motor should be around 100 - 120lbs each.
orbanp
Hello Everyone,
Thanks for the replies!
Interestingly, Chrysler manuals list all their compression ratios for their outboards.
Peter
dazk14
Ensign
Hello Everyone,
Thanks, Peter
Difference between the 2 models is production run.
That motor started life as 160psi motor, so you can do the math on the level of wear...
Presuming, you're using a quality gauge and a good battery.
