Hello all,
I am hoping for so insight into my problem with my 2000- 2 stroke - 60HP mercury bigfoot (oil injected), hard to start, believe there is a choke issue.
I am a new boat owner (and female) and had someone look at my boat and I just want to be sure that I am not going to get "taken for a ride". Here is what I gathered from the guy who looked at it.
It has a push to choke on the ignition key, when pushed, there is no clicking no movement. However it was able to manually choke it and fired right up. I have only had the boat since July and it was always difficult to start, had to keep cranking the engine and it would eventually take. So the choke problem makes sense.
I would just like to know from your experience what low cost things should be checked first?
I am trying to figure out if there is a choke solenoid that should be checked for corrosion, if it could be the ignition switch itself, or ignition wiring to the choke.
The guy mentioned wiring as a guess, he only briefly looked at it and wants to bring it to his shop.
It was also suggested that i have the carbs rebuilt, he did not get into the carbs, just said they had not been touched.
I need help from you experts out there. Please ask any questions that you need.
Thank you in advance for any info you can provide.
