Re: 60hp Evinrude too rich
Vic.... That sound like you have a fuel restriction, and in all probability it is being caused by an "Anti Siphon" valve that can be located where the rubber fuel hose attaches to the fitting on top of the built in tank. Those things are notorious for sticking, and before they get too badd, they will operate fairly well at a high rpm due to the fact that the vacuum being generated by the pump at the high rpm will keep the valve open. However, at the lower rpm, the vacuum is much less and the "Anti Siphon" valve sticks. This causes a fuel restriction BUT the VRO is still operating as it should, and as a result, less fuel gets drawn into the VRO but the normal amount of oil is being drawn in..... resulting in a very rich (oil) mixture.<br /><br />The cure? Hey glad you asked! Remove that anti siphon valve if it exists. (Aluminum fitting about 2" long) and knock out ther inner componets (Spring, ball and ball seat), then re-install it as a straight through fitting. Hope that cures your problem.
