mike-the-cobra
- Joined
- Aug 28, 2007
- 117
All 3 carbs are overfilling, gas everywhere. I am thinking it is the VRO pump (I think it serves as a fuel pump also?). Immediatlely after startup, the engine floods out, gas driping out of the air intakes and gas overflow tube.
If I disconnect the fuel line, the engine will start and run, using the gas in the carbs until it runs out. reconnect fuel line and they all flood out.
Am I right in thinking it is the VRO pump? I tested the voltage at the electric choke, and it seems to be getting voltage when the key is pressed in.
