I recently spun the prop on my 60HP johnson outboard. I left the prop in for two weeks to have a new hub pressed in. When I went to pick it up he realized he had not sent it in at all!<br /><br />He loaned me a 15 X 12 3/4 prop to use instead of the 17 X 11 3/4 I had. When I used it the engine overheated.<br /><br />Is this caused by the prop as it never overheated before?<br /><br />The engine cut out as I was coming into the dock at low revs. What do I check for damage?<br /><br />If I placed the washers incorrectly, would this cause the problem?<br /><br />How should I handle the boat from here? Take it out and retry, change the water pump? Pull the boat and the motor for checking?<br /><br />The water was coming out the pee hole but was sputtering and hot.<br /><br />All help is greatly appreciated.<br /><br />Thanks,<br /><br />Liam
