Re: 60hp overheating?
Alright I've been away for 7 weeks and now I want to get this buzzer situation figured out. Like I said when I start it it will run fine for the first 2-3 minutes on the muffs. The tell-tale stream will get increasingly warmer. For reference the tell-tale is routed from the exhaust plate. Finally the warning buzzer comes on....but it is the beep beep beep. I know this is the low oil alarm, but the oil injection is disconnected and all the wires have been cut and sealed up.
Now....to make the story a little more confusing. Once I turn the engine off obviously the low oil alarm stops. But when I turn the key back to the "on" position it has the steady alarm...ie. overheat???? I don't understand this one.
I can hold my hands on the cylinders heads for a couple seconds so they are not too hot (normal I'd say). But the exhaust plate is very hot. However I know the overheat sensor is located near the #1 cylinder so I don't know how a normal temp cylinder head and hot exhaust plate could make the alarm go off.
Sometimes, if I turn the engine off for a couple of hours and then turn the key back to the "on" position the alarm still goes off. WHat always cures the problem is if I disconnect and reconnect the small harness which routes the wires for the tach,overheat,low oil, from the engihe to the control/throttle box. What the hell is going on here? I know it is a simple system, but I am at a lost. I mean...low oil alarm...then overheat???
confused and somewhat irritated
-andy
