61 10hp evinrude wont shift into forward
I took it to shop yesterday just to have it looked over. It runs like a charm but will not shift into forward. The guy said its probably the clutch dog. Is this the only thing that could make it not shift. It goes into reverse and netrual no prob. I had the lower unit off last week putting a new spaghetti gasket on. could i have put lower unit back on wrong to cause this problem
F_R
Re: 61 10hp evinrude wont shift into forward
Shift rod connector? Does the screw go through the notch in the shift rod?
Chinewalker
Also, since you had the skeg off, check to make sure you got the shift fork pivot screw in correctly.
It is not the clutch dog. A worn one will still go into gear, it just won't stay in gear.
it has to be the shift fork pivot screw. I still do know exactly how to get it lined up right. Do i need to have it in a certain gear for it to line up so the screw will go through the pivot hole..
looking for help on putting the shift fork pivot screw in correctly. is there an easy way or a trick to lining it up
ExxWhy
On my 54 Johnson 10 HP, I had a little trouble getting the shifter right the first time. All I can say is fiddle with it a little and when it pops into the right place, you'll know it. Make sure the rod slips into the connection joint all the way. There was a little detent in the end of the rod that fit around the screw that holds it all together. Not sure if yours is the same, but I would suspect it's very similar. Main concept is to play with it until it shifts right without it running and you should be good to go. From the sounds of it, that's your problem right there, nothing more serious.
samo_ott
Try putting the engine on it's side and get an awl or ice pick and a good flashlight and pick at it until you line it up and then put the screw back in.
Chinewalker
Another idea, did the shift fork seat properly in the collar on the clutch dog? If not seated, that could cause the problem, too...
F_R
Agreed. If you got the pin in, it should work. Unless the fork and cradle aren't in place on the inside. But it shifts to reverse and neutral, so that makes me wonder it we are even on the right track.
i wont be able to work on it till Friday night...i think the bolt went underneath the fork altogether. it. went together way to easy. Thanks for the help ill post tomorrow night to fill everyone in
