Hi,
I bought a '61 Evinrude Lark 3 40HP last year. It ran great when we got it, then in the fall it would only go about half speed at full throttle. I changed out one of the coils thinking that was the cause but when I took it out it did the same thing. This year I took the flywheel back off and tested all the connections. One of the spark plug wires was toast so I changed it out. Everything else tested fine. Put it back together and it fired up no problem. It idles and goes slow great but as soon as I start to speed up the engine stalls out.
I pulled the plugs, they're both new. The top plug is covered in oil, the bottom plug is clean. I can start the motor with the bottom plug connected and the top plug not, but I can't do the opposite. The top plug does spark as my body can atest to. I tested it on my meter to.
Anybody have any ideas? I hoping someone will say it's the carb, because that I can fix. I have nothing to test the compression with.
Thanks!
Thanks!
