61_Johnson
- Joined
- Jul 19, 2008
- 7
Morning guys!
Having a problem keeping my motor running, thought somebody can give me a tip on whats going on. Keep in mind, I am no ace mechanic!
When I crank the motor, it starts off running fine but the throttle is sluggish, you may gap it wide open and it revs up one time, the next time it may not rev up but half way. It will run for about a minute and then just die like it is running out of gas. I pulled the plugs and they are soaked with gas. I clean them off, start over and it does the same thing. I just rebuilt the carb, all new fuel lines, inspected the fuel pump and all that jazz. Also, it is running kind of rough and at WOT it is smoking a good bit. I am using 24:1 oil/gas mix.
Any suggestions? Thanks!!
