JKTrevecca
- Joined
- Sep 20, 2009
- 110
Good evening all..
Getting ready to put the boat up this fall decided to take it out another time or two. Well.. After changing the lower unit oil with Marine 90w gear oil, I had some problems. The old gear oil looked fine. No water at all. I did notice that it seamed much more thick than the replacement oil though....? Is 90w the correct stuff?
The boat doesn't shift into gear/out of gear like it is supposed to. It shifted into reverse at the dock, but then wouldn't come out of reverse. (picture me running around backwards near the dock for about 5 minutes
) After repeated attempts, it shifted out of reverse and into neutral, but wouldn't go into forward. Then... again, after repeated attempts, it finally went into forward gear.
Any idea's on what might have caused this? Could the gear oil change have done something? Once it's in gear, it stays like it is supposed to.
As always... thanks for your input.
jason
jason
