62 40 hp adjustment
Woodstock60
Well, I finally have this motor running fairly smooth, Idle's nicely, runs good at med and WOT. The only problem is when I ease of the throttle to move slower she wants to die out momentarily. almost like its flooded, she comes to right away if I give a little gas, but its not right, Just looking for any input. Thanks
kodibass
Re: 62 40 hp adjustment
if you cleaned the carb did you remove the welch plug and clean the transition holes? might try giving the carb a very good cleaning and see if it helps.
F_R
Is the vacuum cut-out switch wired correctly, including the safety switch?
Are you sure the throttle/spark advance synchronization is set up correctly?
