62 Johnson seahorse 10
ukkev
Just a quick question....
What is plug fouling and how is it caused?
I have a seahorse 10 That whenever i take the spark plugs out one is dry and sooty, the other wet with oil?
On tick over and even when you rev it, it does sound to be running uneven.
Makes no difference swaping plugs around, its allways the same cylinder that is left with the wet plug?
Any ideas on whats causing this and how to fix it are much apreciated!
kev:)
tashasdaddy
Re: 62 Johnson seahorse 10
sounds like you have a bad coil, each cylinder has a coil under the flywheel. the wet one is not firing.
