63 evenrude flywheel removel HELP PLEASE
JB
Re: 63 evenrude flywheel removel HELP PLEASE
PLEASE DO NOT SHOUT!! That is what capitals do.<br /><br />What is this? A 2hp, a 75??<br /><br />What have you done/tried??
fishwy8
sorry about the capitals. the engine is a 40 lark V
dkondelik
'mornin' fishwy,<br /><br />you'll need a gear-puller or stearing-wheel puller. you can get one at about any autoparts store. do not get the type that grabs the rim of the wheel. insted, get the type that bolts to the holes in the top of the gear/flywheel. i believe that your flywheel will use 3 of 1/4x20 screws (1/4" x 20 threads/inch).<br />Soak the shaft with penetrating oil for a while before attempting to remove.<br /><br />Take your time. these buggers can be a bit sticky.<br /><br />Good Luck<br />HAVE FUN!
