63' Johnson 18hp, Sealant
hammerhandle
Im assembling the crankcase cover to the block and need to know if the anerobic sealant is the correct kind to use and where to apply the sealant ..Should i put some around the outer upper and lower bearing seats and the rubber o-rings.
Paul Moir
Re: 63' Johnson 18hp, Sealant
Yes, put sealant on everything: the flanges and the bearing o-rings. Just don't gob it on or allow any to come in contact with the bearings' internals or seal faces. The o-rings alone cannot be trusted to seal.
I've never tried anaerobic sealant on these, and I wouldn't trust it to work. Some areas really don't have a lot of flange area and the spaghetti is intended to be the sealing surface. I doubt the anaerobic stuff would work very well on the o-rings. 1000 sealer is the proper stuff (Boat armour brand or marpox). BRP no longer provides it, and rather offers 847 Adhesive Sealant (a 3M product) for that application.
I have had great sucess with Permatex Motoseal Grey in that application. It is meant for sealing 2-stroke crankcases and is very much like 847 and a little easier to find.
