After filling oil in gearcase I see it is leaking from the prop shaft, precisely where the shaft emerges from the gearcase. It is about an ounce a day for the last few days. I have the rebuild kit, but I cannot not find a clear enough diagram instruction in the parts manual or the Seloc manual. Is this just a case of openning the gearcase, putting the o ring and seal in and resealing it with the new gasket. Should a sealer be used with it and what type? Thanks.
