Re: '64 johnson 9.5 output shaft..
the shaft from the power head that gos down into the gear case in the lower unit. its scarred bad the whole lenght of it for some reason. im planning on rebuilding the lower unit, i just wanted to know if you could buy this shaft new??? the motor is one of the flat top twin cylinders.
thanks
