Re: '65 40hp dropping lower cylinder
Well, this hasn't been a banner day. With half time coming up, it's 10 zip Giants.<br /><br />In addition, I've busted three bolts off in the flywheel trying to pull it. 1/4 20, 2 1/2 inch, shouldered zinc plated steel. All bolts are torqued down to the shoulder, pull is straight, and I'm holding the puller with a pipe wrench (instead of a big screwdriver on the flywheel teeth so I'm not twisting the bolts).<br /><br />Three separate efforts, each time, busting a different bolt. I torque the center bolt damn tight, and then pop the center bolt with a big mallet, then torque again .. torque, pop, torque, pop. I sprayed liquid wrench on the crank before the last try and let it sit about 5 minutes.<br /><br />I've been lucky and have been able to drill and easy-out the busted bolts each time.<br /><br />Will let it soak in liquid wrench today and get more bolts. I put the flywheel on myself in August per spec (100 ft-lbs, I think).<br /><br />Any ideas?
