65 40hp Johnson super seahorse won't start
throne1
I had to replace my fuel line that goes to the in connection on the fuel pump with a 5/16 fuel line.<br />I also changed my plugs from what I found out were lawn mower plugs champion j19lm to a champion j4c gapped at 0.30 now the engine will not start it started right up before any suggestions
Paul Moir
Re: 65 40hp Johnson super seahorse won't start
Are you sure you put the spark plug leads on the right way around? Do you have spark at all?
throne1
I checked and The leads are on the right plugs and it is definetely sparking strong.
Lark40
Try spraying some fuel/oil mix directly into the carb. If it fires, then pour fuel/oil into a small funnel into the carb intake hose.<br /><br />If it runs OK, then you have a fuel delivery problem, possibly the pump.
throne1
Thanks for your help It was the fuel pump Ihad an extra one put it on and runs great now.
