Thanks to anyone who could help me out here. My grandpa gave me a '65 6hp Evinrude fisherman he has owned for years, I took it a small motor class last October and rebuilt the carb. I also took apart the lower unit, and although the unit looked as if it had never been taken apart, the mechanic said the impeller looked to be in great shape and said it will be fine. Tested spark plugs with some clip on device and both worked, one was a little fussy but still got it to fire. Then it was stored for the winter.
Fast forward to now - I have finished up my aluminum boat "restoration" this past week and wanted to take out the new rig w/ the 6hp to test out. Before I went to the lake I decided to grab a trash bucket like I've seen others do and try to start the motor in the garage. However I only had a trace amount of gas so I just pulled the starter rope a couple times and the motor did kick on and sputter. Died out but I assumed this was due to the lack of gasoline. So off I went to the lake. Filled up the tank, launched, put outboard in neutral, primed the bulb until firm, pulled choke, pulled rope, and the motor started for a bit and died out. After this happened twice, the motor stopped responding when I pulled the rope. Nothin. Nada. Worked on it for half hour and couldn't get it to come close to turning over. I assumed spark plug problem and returned home dejected. When I returned home I was frustrated and pulled the bucket out again to take a look. Motor started up on 2nd pull and for the first time I got the motor to idle at a nice pace (aka water splashing and a general mess in the garage). However I did note some white smoke appeared as the motor idled. What the heck happened? Did I flood the engine originally? Starting issue like spark plugs? Compression? I don't want to have a reoccurring problem but it was nice to actually get the thing running so I know it works. Again I would greatly appreciate any insight on the problem as my knowledge is limited, yet expanding "rapidly" after countless hours on this board. On a more positive note my trolling motor is running smoothly.
