As mentioned in previous threads, my attempts at getting this long dormant engine running continue. I have installed a new impeller, plugs, fuel line and re filled the lower unit. When running it last Friday, the engine started easily, but would not idle, and had a steady low speed miss. When I disassembled the carb, I found white build up suggesting water intrusion in the reed valve area, and in the throttle venturi, which was restricting operation of the throttle valve. I removed the low speed needle valve, and needle valve nut and found, no packing, no O rings or springs, as shown in an Evinrude diagram. The "needle valve nut" ,screws into the carb body, and the low speed needle valve ( or slow speed) into the nut. The tip of the needle valve sticks into a hole in the carb body.
I'm missing parts it seems, would these "needle valve packing, washers and spring", come in a rebuild kit.
here's a picture as they came out of the carb, I see nothing in the carb body itself where they screw in.
Thanks for the help
Thanks for the help
