jimmehoffa
- Joined
- Jul 20, 2004
- 4
so its the dead of winter in Minnesota and I am thinking about my boat..
I have a 1968 or 69 65 hp Johnson VXL 4 cylinder outboard on my 1968 Glassbar Avalon. The motor generally runs OK ...if... it has a fresh set of plugs, preferably Splitfires.
I need to change the plugs out at least every 20-30 hours of running. It starts good, has good high speed power, but marginal low speed operation.
It will misfire, stumble and foul out the plugs.
I have worked on the carbs, quickie cleanup and rebuild with gaskets.
I am considering tearing into it this winter. What would need attention after 40 years of duty? (I doubt that the motor has had 600 hours of use in its life)
It has never been apart.
thanks
thanks
