Hi Guys Have I missed something I need to change the impeller on my Johnson 65, I have removed the gear link bolt the 7/16" trim tab bolt, the 1/2 bolt under the trim tab, the 5/8 bolt to the rear of the trim tab, and the 4 9/16" bolts that connect the gearbox to the exhaust housing. But the gearbox has stayed put, I have tryed to gentley prize and tap the gearbox with a rubber mallett it has moved about 3/8", I don't wamt to use to much forct and damage something. The engine had not been used for years and then only light use, I would be greatfull of any help Jon
