On my 65 RKL 2Johnson, I put in new points and condensors that seemed like it took care of a miss that I had. I took the boat out to the lake today and had a different problem. When throttle was advanced to full it seemed like I was getting about 1/2 throttle. Brought boat back from lake and set motor in test tank. Took cover off, started right up. advanced to full throttle and motor reved up to where I think it should have been, do not have a tach. Did I seem like a fool or what. Did some other minor things to the steering, put cover back on, started just to check. Started right up, advanced throttle up to full throttle, reved up then RPM backed down to about 1/2. Removed cover, reved up to full and stayed. Put cover back on and the motor went back to about 1/2 RPM. Opened trap door where the pull rope and carburator access is and the RPM went back up. The cover seems to be a sealed unit, there is a possible path for air where the transom mount attaches to the motor. It is not blocked by anything that I can see.
Any thoughts from the more seasoned people here?
