'66 110 problem again - any ideas?
rustvyper
Thanks to help on here I got the old 110 running...it ran like a dream until the prop bushing rotted away, got that fixed...heading to the lake & had a tire blow out. No sparte so I had to leave the boat. Took the engine off & put it in the car. When I finally got the boat in the water, really rough idle, it misses & would stall out & die when I tried to put it in gear & give it some juice.<br />After it heated up, I was able to run around the lake at full power.<br />Next day, again, didn't even want to act like starting, finally got it started, but it never acted right.<br />Today I replaced the spark plugs, it starts but won't stay started. I find the problem is the new float I got is stuck, but when I fix that, now it won't start at all...Any ideas??? Thanks.
Laddies
Banned
Re: '66 110 problem again - any ideas?
Have you set the float drop as well as the level to much drop and the inlet lever can get caught on the float spring
