skinny1965
- Joined
- Aug 3, 2010
- 148
ok this old 40 hp has fired in past but never run constant. it has spark and has had fuel. when it fired and run (till ran out of fuel) was at full throttal.
the mag wires are not hooked up right now. since it seemed like it was a fuel issue I removed the carb and opened it up the needle was missing for the float . I recieved another and proceeded to clean the rest. What is the base setting for the low idle needle (in center top above carb bore)this apeared to only be 1/2 turn from bottom.
need some pointers to getting this to run steady
