flintcreek
- Joined
- Apr 19, 2009
- 90
I am stumped on this one. 66 model fd-19 18 hp has new coils, points,condenser and plugs and wires. Jumps fire 1/2" on tester and compression is 120 on both cylinders. I have cleaned the carb.
Now for what it is doing. It does not run at WOT. Took it out this morning and it Idols fine, would not open and run at WOT. So I screwed the idol screw all the way in and it started to open on up and run at WOT. Packing around the idol screw seemed loose so I took it home and put in new o-rings where the old packing was, took it back out this afternoon and it would not open up and run, even if I screwed the idol screw all the way in. Any ideals.
Thanks,
Flintcreek
Thanks,
Flintcreek
