riktweed
- Joined
- Feb 14, 2011
- 26
We were baffled that our outboard started, idled, and ran great with the earmuffs on, but when in the water it stalled as soon as it goes into gear. When we took it home, it again ran fine at various throttles FWD and REV until we put into a tank of water.
So I pulled the prop and with the prop off it will run fine even in the water. Seems like prop load is killing it. Would there be anything besides bad compression that could cause that?
No fuel problem (runs fine out of water no matter what gear or throttle)
No electrical problem (ditto)
Will do a compression check next, but any other advice would be appreciated greatly.
Thanks.
PS) There is an outlet port at the back of the shaft where water sputters out along with some steam. Should this be a steady flow of water or not? I am concerned my problem might have started with a cooling problem.
Thanks.
