I have completed the tear down, carb cleaning, points cleaning and rebuild of my 66 McCullough 7.5 Everyone is correct, these motors are not the easiest thing to work on.
Model 574.60607
I checked the impellers while I had the motor torn down. The impeller on the top is for the Bail O Matic. The impeller on the bottom is for cooling the power head. The bail o matic impeller was in good shape so I moved it to the bottom housing. the motor actually runs pretty well now and I have water spitting out the exhaust port.
I would like to get a new impeller so I have a spare. I know I can probably get one from Impellers by Brian. I was just wondering if anyone had been able to find an impeller from some other make of outboard that might fit my McCollough. I thought I saw a post on here where someone was able to use an impeller from a 10hp Merc but not sure if that would work for my motor.
The impeller I have is 1 5/8" in diameter
9/16" Deep
7/16" shaft diameter
9/16" Key Hole opening.
Picture is attached. Let me know if anyone has had any luck crossing this impeller over to one that is readily available.
Thanks,
Model 574.60607
9/16" Deep
Thanks,
