1966 Rude 9.5 Sportwin, 9622A<br />Intermittent sneeze at all rpm. About half of the time she runs great. Maybe 1 or 2 sneezes right after started when still cold. Other half of the time, even after warm-up, every 20 0r 30 seconds, a sneeze, regardless of rpm, idle, mid throttle or wot. Problem seems to have developed after removing/replace clam-shell housing and leg for painting.<br />Carb has been cleaned, rebuilt, re-cleaned and re-cleaned. New Gas lines & bulb.<br /><br />Reeds? Fuel pump? Crank Seals (no obvious gas/oil here)? I dunno.<br /><br />Other issue. Runs with cowl removed. Lugs hard with cowl on (not enough air). For the six months that Ive had her, this has always been the case (pre and post rebuild). Any thoughts on what could be source of problem? Could these problems be related?
