Replacing all bellows & lower cable , Is it worth the effort to try & remove the hinge pins holding the assembly to install bellows or is it better to make it work while in place? Have old style I guess pressed pins. Have completed the job on newer threaded pins & know how much better that is.
Also anyone know what size tap needed to install newer style shifter cable in bellhousing assembly? Need some instructions on the tapping process...Thanks.
