67 5hp evinrude outboard. Having trouble with the engine getting hot. Before problem I had sheared a pin and when i replaced the pin i found that the seal around the prop was bad. I pulled off the prop assembly cleaned out water and replace with gear oil and all new seals. Now engine gets really hot, and when i start it in full choke it starts, but after running it for about a minet i take the choke off and the engine revs high and then sputters out. I have the mix nob turned to rich and am running a 50:1 mix. I took it apart again and check to see if the impeller for the water pump is turning and it is.<br /><br /><br />Thanks,<br /><br />evinrude trouble
