Lion hunter
- Joined
- Apr 9, 2005
- 1,529
Can someone explain the theory of operation on a 1967 60hp thermostat.
1. How does the small thermostat operate?
2. Is there a bypass that allows water through before it opens?
3. Also, the brass nipple on the thermostat, I assume that this heats up and raises the valve above it. The nipple was loose and able to be pulled from the body. Is this correct?
This was the 1st time I ever tore in this type of thermostat. The top 2 pieces came off as one part so I set it aside to inspect the rest of the body. Needless to say it blew up while sitting there and I spent the next hour looking for the 2 springs. I had to enlist the help of my 4 yo and bribe with candy to get her to crawl around and find the last spring. Kind of handy that I had already found one to show her an example.
I'm pretty confident that it is all together correctly now, but I am curious as to it's operation.
Other question: I replaced the impeller just because the motor is new to me. The old impellar didn't look like it had any wear what so ever. In fact there is a "rib" where it looks like the top and bottm halves are molded together. That rib on the old one is still present. When this occurs does anyone just keep it for a spare? I was thinking of pouring oil on it and sticking it in a ziploc bag. Most everyone I have ever replaced needed replaced so I'm wondering if it's worth the $25 to keep this one.
