a70eliminator
- Joined
- Sep 9, 2007
- 3,762
Results of my comp. test not to good, I've used this motor alot and think I've almost worn it out. I've always kept it tuned and clean, have gotton 28 years of service. I'm thinking the cylinders are in pretty decent shape, would it be reasonable to fit a new set of rings without any major dissasembly? Could it be as easy as pulling each head fitting the rings and reassemble?
While running the motor on muffs I pulled each plug wire one at a time just to hear the effect of each cylinder, and #4 the one with only 60psi is hardly contributing anything, the others note a definate miss, but that #4 doesn't make as much of a difference, which to me just reinforces something going on with rings, also by adding a squirt of oil the comp. goes right up to 120. I didn't even try it the others as i'm sure the same will happen.
Is there anything else that should be addressed during a re-ring job that I'm not thinking about? It looks like a fairly simple task for your above average backyard mechanic.
