67 johnson 45hp
J Headrick
how much should i expect to pay for a 67 johnson 45hp. owner says it runs pretty well. dosen't look all beat up or any thing.
JB
Re: 67 johnson 45hp
Howdy, Headrick.<br /><br />No test or demo. $100.<br /><br />If it passes a compression test and has spark on both cylinders, $200. <br /><br />If it passes a runnning demo UNDER LOAD, $300.<br /><br />Just one opinion. I'm sure you will get others.<br /><br />Good luck. :)
steelespike
Re: 67 johnson 45hp
I wasnt aware Johnson had a 45 in 67 thought only a 40 was available in that range.??
Chinewalker
Re: 67 johnson 45hp
Spike's right. To my knowledge, Johnson has never marketed a 45hp model. in any era... Might want to get some more information like model & serial number...<br />- Scott
Bear
Re: 67 johnson 45hp
No 45 hp ever? Is this model 45 cubic inches, 45 hp or just the model name? Johnson V-45 <br /> :D <br />The 1929 Johnson P-45 is a 12 hp and 29.78 cu. in. I think you are right again Chinewalker.<br /><br />There was no Johnson 45 hp in the 60's or later.
J Headrick
Re: 67 johnson 45hp
you guys are right, the info passed to me was wrong, it is a 40hp
