Am checking out recently bought 67 Johnson 6 hp.<br /><br />1. Pulled lower unit to check condition of water pump per service manual instructions. Lower unit came off exhaust housing fine with drive shaft still attached. Impeller checked out fine.<br /><br />Now for reassembling unit. Looks easy per manual, but how do I get splined end of drive shaft into crankshaft splines (way way up inside exhaust housing) while at same time aligining water tube and shift rod into proper places? Do I need three hands, two heads?<br /><br />What grommets or gaskets should I replace while doing this?<br /><br />2. When checking the timing, the service manual refers to a timing fixture. Is this necessary, or just handy? Can I get this fixture at a reasonable price from a Johnson parts store?<br /><br />3. When disassembling carburetor I noticed rubber cam follower had a groove worn into it. Can I replace this with a nylon bushing of similar size?<br /><br />Appreciate any help you guys can give me.<br /><br />Bednick
