67' Merc 650 Tach issue
suttonj
I recently purchased an old boat with a nice 67' Mercury 650. The seller gave me a tach but told me he could never get it to work.<br /><br />Looking through the forums I descovered that there is a tach plug/jack at the front of the MerControl, and I believe I know the correct terminals for that plug.<br /><br />Trouble is I don't think the tach that he gave me works. It is an old SUN Tach.<br /><br />I wanted to buy a newer tach, but I don't know how many stator poles my alternator has. From reading the forums I'm guessing 12, but I can't find anything concrete for a motor that is nearly 40 years old.<br /><br />What kind of signal should I have at the tack jack on the front of the MerControl? Is it just DC voltage that changes with the RPM?<br /><br />Thanks for any advice?
Laddies
Banned
Re: 67' Merc 650 Tach issue
Its 12 pole 6 pulse you willn have to move the tach sender wire to the rectifier
suttonj
The Rectifier has two wires from the "Alternator flywheel" and one (RED) that goes to the "Switch Box Assembly". I assume it goes to one of the two directly from the alternator, correct?<br /><br />The Old Sun Tach says it is for 4 cyl 2 Cyl. I'm wondering if it is not the type that should be connected to the alternator.
Laddies
Banned
The sun tach goes to the mag but a new style goes to either yellow on the rectifier
