67 v4 60hp gear case R&R question
a70eliminator
Hope someone out there coach me reguarding the forward and reverse gear. One gear has bronze slip bushing while the other has what appears to be a bronze pressed in bushing I can't remeber which is which, they both appear to be the same other than the bushing, could the bushing that appears pressed in actually be seized? Also my prop shaft has no hole for spring and detents for the clutch dog, it's a manual shift if that means anything but the book shows the detent spring for both units, I looked over mine carefully several times and there is nothing but spline, no detents.
