68 18hp evinrude conversion
aprilrose
would like to convert from manual throttle /shift to remote control,is it possible? I got steering /cables in boat/got control box and cables/question is how to hook to engine what /where /how to get or use cables properly,not clear on hookup to motor,what is or how to use retainer/ anchor block or whatever do I need. if I had an extra $$$ or two I would have that manual your thinking about,luck has it I'm broke thanks for your thoughts
tashasdaddy
Re: 68 18hp evinrude conversion
post some pictures of what you have. both side of motor, cable ends, control box, steering end that goes to the motor. then i will have a better idea of what you have. and can help better.
BoatBuoy
AR, you'll need this, available on this iboats site.
http://www.iboats.com/OMC_Johnson_E...84727050--**********.124157864--view_id.40268
