'68 20hp johnson lower unit lube
dlynne
Playing around with an "inherited" '68 20hp Johnson.
Drained lube from lower unit. It didn't have but a coupla oz. in it and it was "tan-milky" (?). I guess I wasn't so surprised at the consistancy of the fluid as I was that it had so very little it had in it. If the water was leaking into it, I guess I would have assumed there would have been more total fluid in it.
Either way, with the unknown of how long it has been that way, I would assume that the potential for major problems is there?
kbait
Re: '68 20hp johnson lower unit lube
Fill it with new lube, install new drain plug washers, and give it a go. After a run or 2, let the motor sit upright for a couple hours and pull the lower drain plug. If it's water or milky grease, you have water intrusion. Good luck!
