Re: '68 33hp johnson won't start with plugs in
You've got the wrong solenoid. You need one like SW622
here. <br />Blown up ignition coils are caused by connecting 12v to the ignition system. The battery and ignition system should be completely separate.<br /><br />The proper wiring for the cutout, solenoid and safety are as follows:<br /><br />Key switch (S) position -> one small lug on the solenoid.<br />Other small lug on solenoid -> base of vaccum cutout switch.<br />base of vaccum switch -> neutral saftey switch.<br />neutral saftey switch -> ground. <br />Top centre post of vaccum cutout switch -> one magneto lead from beneith the flywheel.<br />Top centre post of vaccum cutout switch -> One key switch (M) position terminal or kill switch.<br />Other magneto lead from beneith the flywheel -> other key switch (M) position terminal or kill switch lead.<br /><br />Check to be sure your vaccum switch is not shorted somehow (you'll have to disconnect the leads from it to find out). That in combination with using an automotive solenoid will cause a coil to pop if your wiring is correct. Check your neutral saftey switch too - it could have been fried by the incorrect solenoid as well. Order a repair manual from this site or an OEM one from one of the following locations:<br />
TheOutboardWizard<br />
Mastertech<br />
Marine Engine<br />
Ken Cook <br />Iboats sells new ignition coils, pn 18-5181 cheap.<br /><br />Correct solenoid schematic:<br />
<br /><br />Incorrect automotive type solenoid:<br />
<br /><br />Hope this helps!
